Forge BPV question
2003.5 Titanium Gray MSP
So i ordered the Forge BPV from Corksport. I've read reviews about it, seen videos of it. Everything seems to suggest that it makes a different sound (one described it as "two swords clanking.") The sound was the biggest review comment.
I installed it last nite, and noticed exactly zero difference, both in vehicle performance and sound. It still does the "turkey."
What'd I miss? Is there something else Im supposed to do, or am I just stuck with the turkey?
do you have a green spring or yellow spring installed?
do you have a proper boost/vac signal tapped or is it shared with the line to the wastegate?
Jeff you are thinking Forge WGA, he has the BPV. I had the forge BPV before I went to a FMIC setup with the HKS SSQV. The Forge works just like stock but flows a little better and is louder. That's all you get until you upgrade your piping and BOV.
