Flywheel specs?
JB150SC
Hello, Im new to the forum. I don't own a MS6 but I work for a small independent repair shop and I'm in the middle of replacing a clutch in an 06 MS6. It has 40k on the clock and the clutch exploded. I pulled the dual mass flywheel off and there seems to be a lot of play on the secondary mass. Problem is I cant seem to find any specs on how much play there should be. There is also some lateral movement. Ive never seen a dual mass flywheel have this much play. I was wondering if anyone else has any experience with these flywheels and if it needs to be replaced what would you recommend for an aftermarket flywheel, as I dont think the $1200 Mazda wants for a flywheel is justified with all the problems other people are having with their clutches. Thanks
let me know if no one else posts on this.. I own a shop manual and can look this up.. but, i dont wanna get the specs wrong.. so you might need someone more informed.. (help) if not, i can xerox it if needed?? the manual was like $120..
i changed the flywheel on my ms6 used fidanza 11 lb light its grear but make sure its balanced that play on ur stock one its not ok
