Hello, Im new to the forum. I don't own a MS6 but I work for a small independent repair shop and I'm in the middle of replacing a clutch in an 06 MS6. It has 40k on the clock and the clutch exploded. I pulled the dual mass flywheel off and there seems to be a lot of play on the secondary mass. Problem is I cant seem to find any specs on how much play there should be. There is also some lateral movement. Ive never seen a dual mass flywheel have this much play. I was wondering if anyone else has any experience with these flywheels and if it needs to be replaced what would you recommend for an aftermarket flywheel, as I dont think the $1200 Mazda wants for a flywheel is justified with all the problems other people are having with their clutches. Thanks
