Engine Damper Installation Pics.
wrleo
not completely, but I'm sure it helps... I would still get an AWR front motor mount... but its probably the easiest piece on the car to replace...
someone with just a front motor mount or all stock motor mounts needs to try it.
I have these installed on my car, thats actually my car posted. I have all stock mounts. After the install i ran the car up and down the street in front of weapon-r, i asure you there are no wheel hop, no vibration in the cabin, and shifting from 1st to 2nd is the awsome!
that would be me :) I have to call Leo on monday, I want to see if there is a way to tighten the damper a little more
check the other thread for my install with the GTSpec bar, I am going to update the pics here in a min
I thought you had both AWR mounts though Jamie... guess I was wrong... (thumb)
I do but I have never installed the rear, I am waiting until I pull the motor :p
I have all stock mounts and a turbo kit...lol....I just might be getting in on this..
tekkie, try installing the WR bracket UNDER the strut bar bracket. if that works, you wouldn't have to take out a notch on the bracket.
but Jamie has a GT spec bar anyways.... so I guess that doesn't matter for him. but I see where you are coming from.
thats what I did
