Bennett2043
- Jeep Liberty
Anyone know how to wire up a dual battery?
Thanks
Ben
Thanks
Ben
that is still not the answer to his question LOL (headshakegot wake? said:then pop, fizzle, no more batteries![]()
Bennett2043 said:Why pop fizzle?!?
I was thinking about running dual optimas in parallel. Did you use a isolator?
Ben
Bennett2043 said:My alternator should be able to handle it, since its a 136 amp. But this summer I will be putting in a 200 amp.
smithers_0990 said:Please post pics of the lighting system so the forum members know what they are dealing with.
got wake? said:bah, we don't need no stinking pics(chair) current draw is all that is important. and since you are dealing with a constant draw from lights, and not the duty load of a huge stereo system that is constantly changing it's current demands, it's a slightly different ball game.
so let's start over. what is the total current draw of all the extra lights, ie not the stock headlights? do you turn on your lights with the jeep off a lot? if so, WHY?
the reason why ford diesel trucks, and any other vehicle that comes with multiple batteries can do it is that the reason why they have multiple batteries is for starting the vehicle, and that's it. the only time the voltage is low is during cranking. put in a large system or add a bunch of amp hungry accessories, and you will kill the batteries in a factory multi battery setup. with extremely high torque engines you have to have MUCH higher cranking amps to turn the engine over, and with diesels you might have to turn it over quite a few times to get it running. but once it's running, there is no current being drawn from the batteries, they are only charging. look at tractors with 4 of the biggest batteries you can find. they need the high cranking amps that you get from multiple batteries. when you wire 2 batteries in parallel you keep the voltage the same, but double the cranking amps. that's why in a lot of army equipment they use four 12 volt batteries. 2 of them together wired in series to get a 24 volt system, then the 2 pairs run in parallel to double the cranking amps.
the ONLY reason to add a second battery is for more CCA's, and for more reserve capacity with the car off. other than that they will hurt you more than help you.
