Drivetrain lash...worries
Thanks! I appreciate the pics.
Hmm. I feel like my problem might be clutch chatter. I've searched around and some have described similar behavior.
Sveivo said:
Thanks for the idea. About where is the throttle cable located?
This feels like wheel hop, except it's when I try to back out or move slowly around a parking lot. Does yours feel that way?
Hey Sveivo,
It was the flywheel/clutch combo. I haven't had any problems since changing the clutch/machining the flywheel. The machinist stated that the flywheel was warped, ever-so slightly and he said that that would've been enough to give such violent clutch chatter.
Yup, that was the feeling I got. Wheelhop...Exactly!
While searching for a clutch replacement, I had trouble because there are some clutches (high performance, with stiffer engagement, racing) which are difficult to engage and can cause a feeling similar to what I experienced and you seem to be experiencing.
Because of this and because I decided that I wasn't going to do anything else to the car, go-fast-wise, I made the decision to get an OEM replacement clutch from EXEDY; and instead of buying a lightened flywheel just had the flywheel machined.
Jetman, what you're proposing won't work if his problem is in fact clutch chatter. While attempting to diagnose the problem myself, at home, I went through the same test without getting an answer. You're right about one thing...the engine will not move nearly as much with the new mounts.
P5inder said:
Hey Sveivo,
Thank you for posting back so quickly. I guess I need to figure out what to do with the car now.
I will keep everyone update on what I decide to do.
I know...I was kinda lucky, I know a mechanic who works for not too much $$ and I searched the parts out myself.
I paid...
$165 for the EXEDY
$ 65 machining the FW
$150 for the labour
I wish I had the space and tools to do it me-self...(rockon)
Good luck!
I paid...
$165 for the EXEDY
$150 for the labour
Good luck!
Good info, thank you sir.
i got the same problem.... I do believe its the clutch though. I have all four engine mounts torn up i thought that would be the problem. But not anymore because your having the same problem with upgraded mounts....
I also get it at low rpms when i try to take off slowly but its very intermentint and doesn't hapen all the time. It also happens when the road is wet and i try to take off fast but i believe this is wheel hop instead.
Im going to upgrade my motor mounts because its cheaper than purchasing a new clutch. Will see if this fixes my problem but i doubt it after reading this thread..... Must be the clutch.
Sorry it's happening to you too man! Got to be the clutch. I just did some testing and I found a way to take off decently without getting the crazy wobble. It's just a workaround though. I see a new clutch in my future. For right now I figure I will just ride this clutch until it's done or until I lose patience. Whichever comes first ;)
My mounts are definitely stiff because I did the test thejetman recommended. I revved the engine while under the hood. Also I found a perfect viewpoint to see if my engine moves at startup, as I crank the car.
Well, the motor does not move AT ALL. So it's got to be the clutch.
Best of all to you.
thejetman said:
give it 500 miles. break it in nice. no hard starts and race shifting. you will waste that 1k then. after i replaced my clutch with a stage II and lightweight flywheel (at the same time i did the mounts) it took about 500-600 miles before it started to grab hard and really see the effects of the work i did.(idhitit)
I've had the front mount in there for about over a month now. The rear has been in for about 3 weeks or so. Perhaps they will break in more.
they will, especially if you got a new clutch and flywheel. I love the combo i have. It is a ZOOM brand Stage II clutch (it is a four-puck configuration), ZOOM brand light weight flywheel (-7 or -8 pounds) AWR brand mounts ( all but the rear, cause its a PITA) and a motor with only 20xxx miles on it!!!!!!!!
Sounds like a solid combo. I am looking forward to upgrading. Who carries Zoom brand?
AdvanceAuto....it was just shy of 4 bills for the parts. The labor was free because i was havin the engine installed at the same time. It was 1100 quoted for the clutch and my local guy.
hmm new mounts are in and i can still feel a little jerking/slipping/hoping or whatever the hell it is. still only happens once in a while only when trying to take off a little to slow. hmm new clutch and flywheel to the wishlist.
I've gotten a little better at driving since I put the mounts in. But it definitely takes some getting used to.
