PHASE1 - DIY dash mould gauge holder...
ok guys... here we go...
i bought the gauge pod for wrx... i chose that coz is the closest on to flat and its easier to mod and fit into our flat dash pieces....
so i make the pattern from cardbox and draw it to the mazda3 dash piece. and then cut it with dremel...
for the rounded edge, i cut on angle and mark the surface lightly with dremel... reason being, the dremel cant cut small curves coz of the size of the blade...
then i use hand saw with the finest teeth to cut according to the curve line... still abit rough....
then i sand the rough bit off.... i also sand the gauge holder for paint preparation.... if you see in the pics, i stick the gauge holder to mazda3 center piece.... i use epoxy glue... just temporary, coz im planning to put plastic bond on it later...
if you notice, at the back of the mazda3 dash piece, there are plenty of plastic bone structure... becareful when you cut them off.... dont cut too much or you will make the plastic very flimsy.... just cut what you need...
here is the view from the top...
and here is the test fist for the 52mm gauges... i bought oil temp, oil pressure and one ricer gauge (vacuum gauge) - its mean to go up and down as u throttle up or down... i actually only need the oil temp and oil press, but since i get one more space, it wouldnt hurt if i rice it up a bit...
tonight, i'll do the second post... the surface of both plastic are different, but it can be fixed tonight with plastic-bonding, sanding and painting... i want to make it look OEM as possible... ^_^ so wish me luck... hope doesnt look too ricey and tacky...
PHASE 2 - DIY CENTER DASH GAUGE POD completed
well well... couldnt sleep last night... so i ended spending 4 hour sanding and 2 hour painting... :ubbgrin: feel like zombie now...
lets start....
i apply plasti-bond that i bought on bunnings to the gap between the 2 panels.... and also on the gauge holder (coz its surface have texture and i dont like it....) and scrape the excess...
then i start sanding... start with 60 grit, 150, 400, and then 800... u dont need to do this.... but i just want a perfect surface ^_^ its good for painting foundation...
now, test fitting before painting
and start painting.... i use that light to warm it up, coz its bloody cold atm...
and keep sanding between layer using fine 1200 grit.... i put about 6 thin layers...
i use this anti-glare matt black paint...
now before the final layer... i sand the whole thing with 2000grit... and the result was amazingly smooth!!!
finished painting...
colour matched, texture matched...
and i know its annoying, but colour is very important to me... so i spray my light silver gauge ring to the darker silver... closer to mazda3 silver interior hi-light
and FINISHED!!
now i just need to learn how to hook up those bloody gauges.... any hint? :tongue:
i dont know how to hook up the oil temp and oil pressure sensor.... can anyone help me?
lets start....
and FINISHED!!
