Disabling Sirius and enabling AUX.
When I bought my car the PO had Sirius enabled, but I do not want it as I just use my ipod. How do I go about disabling the SAT and re-enabling the AUX port? I assume I have to look at the back of the head unit and unplug one thing and plug another one in, but what do I unplug and what do I plug in? Any help would be appreciated.
Thanks.
you assume correctly, I have not had the HU out, but I recal from reading older posts that there is a single input in the HU so, when you pull the HU you should expect to see a cable marked aux taped up out of the way, and the sirius cable in the unit.
no idea what the colors etc will be though
As he said you're correct. Just remove the HU, unplug the SAT and replug the ACI. The ACI cable is usually taped off to something or tucked behind a panel to keep it from rattling around. The SAT plugs in to the driver's side of the HU...... there should be three things plugged in to it; the large main harness, the antenna, and the SAT plug.
