Dimensions of MS6 trunk?
Pretty sure that due to the awd system and additional bracing, the MS6 trunk is smaller than a regular 6 trunk. By how much I don't know.
well then does anyone know where to buy a trunk liner for the MS6? ive been looking an can only manage to find them for the Mazda6
The standard trunk is about 16 cubic feet, the MS6 trunk is 12.9. The 3 lost cubic feet are due to the bracing between the wheels...this takes up just a bit of space at the back of the trunk. I haven't looked into too many standard 6 trunks, but the general spacing (i.e the framework, layout, etc) should be the same in both aside from the extra bracing.
I would bet that will fit, or will be so close that you can make it fit either by trimming or with a bit of pressure. You're not likely to find one dedicated to the MS6, so if you really want one this is probably your best bet. Good luck.
