DataLogs for Review PLZ
ms6_nate
04 mazdaspeed 3
Hey guys...
Just installed my turbo upgrade and ptp internals. I also have the supporting mods in my sig. I did a couple data logs at low boost and not WOT tonight. Im running the cobb stage 2 91oct tic sri tmic map. Im still learning alot about this stuff, so i was wondering if someone could look at these and lemme kno what they think.
NATE
  • log1.txt
  • log2.txt
I started doing WOT pulls today. As most would know, this map should be 19psi of boost, but for some reason im only hitting 13psi. Any ideas why?
If your getting knock, it could be dialling back the boost. You need to log KR when you datalog.
You installed a BNR stage 3? What are you running for boost control? The factory boost control, or are you running a 3 port? I don't see it in your sig.
Also with a new turbo, running an OTS map is not advisable.
