Have a 2007 CX-9 3.5L
Trying to position the camshaft in both banks to install timing chains - manual says cams in neutral position - I’m just searching for an illustration to show me exactly what position that is. I have the sprockets off w that chain and trying to slide it onto the camshafts but want to make sure everything is in correct position. I have the crankshaft in the correct position per manual “crankshaft keyway is in the 11 o’clock position".
My cams must not be positioned correctly as I’m having trouble sliding on the sprockets of the right bank.
