Custom turbo coolant lines, oil drain, a few stock parts
Hey y'all, I have these for sale, because when I did my research, most VF22 turbos have 10mm banjo bolts...sadly mine are M12...not M10....ugh!!!! The frustration. So for the mean time I have to run rubber hoses until I sell these and get the correct size banjos and banjo bolts. As for the oil return, I accidentally ordered 2.
First thing up:
Fragola -10AN Steel Oil Return fitting.(for welding to oil pan)
Asking - $10 shipped
Next, I ordered these from Techna-Fit. These were custom made length. They are the perfect length to fit these to the hoses running off of the coolant hoses from the throttle body to cool down your water cooled turbo. (Thats if you are running a water and oil cooled turbo).
20" -4an braided steel hose with 10mm Banjo end to -4an female end. Running Fragola -4an to -6an adapter to a Fragola -6an to 3/8" barbs. I know I could have done this a little different but I didn't have time during the day to get these made local, so I pieced it together on Techna Fit. After I sell these, I will do the same thing but get the correct banjo size and banjo bolt size. lol
Banjo Bolts are M10 x 1.5mm and comes with the copper washers.
Asking $40 Shipped.
Here is the pic
Ok here is some stock parts. I honestly don't know what I should list these at but just PM me with offers for them and we can workout a price. Thanks!
Stock Fans (Both wires cut to install my slim fans for my turbo build but you can easily solder them. On the bigger fan, you can easily just swap over the connector. BEST OFFER
Exhaust manifold, with cat and j pipe. Both have working O2 sensors. The rear O2 sensor is 2 months old. BEST OFFER
Full stock intake setup (Mint previous owner had just replaced the rubber intake hose when I bought it in October) I am willing to split the stock intake pieces up BEST OFFER
P5 ecu this can easily be flashed by spicyorange to MSP ecu specs. $40 shipped
Stock heatshield BEST OFFER
Mint oil pan (SOLD)
BUMMPP ( i will also have a lot of stock parts up for sale soon and an oil pan that was used for 2000miles and still looks brand new up soon because I just went turbo.)
So the intake pipe is essentially new? How much shipped to FL 32312?
