Creaking noise when taking off.....
Sounds like I'm not alone in this either. At first I thought it was a huge rock stuck in my tire. Nope. Then I took off the wheel and and inspected the rim for cracks. Nope. Shook around all the brake components to listen for creeks and cracks, nope...
I have a 30K mile check up coming soon and I will have them take a look at it. If its endlinks or some sort of half shaft issue I will have the dealer take care of it under warranty.
i don't get that sound when i take off only when i go reverse and its only 1 click then no more, and i beat on my car every day. but i haven't had time to take it in for it to be checked on.
I got this too I bet it's the exhaust donut gasket, it's gets glazed over and squeaks. Put the car in gear with it off release the e-brake and rock the car see if it makes the same noise. Does it only make the noise when it's really hot or cold?
oki took the car to my guy this morning after work and showed him the sound it was making and left the car with him 4hr later all suspension parts re-tighten control arm bolts loose, cross member bolt. seems solid again
