cp-e HPFpump, Dynos and Datalogs
Status
Not open for further replies.
U siad the timing hits 14. My timing gets retarded during spool up and then gradual rises to only about 12ish. Is the timing you are datalogging stock or is that the advanced timing?
My timing was stock. That's one of the differences btw this tune and mine from this summer. We tried adding a degree and saw negligible benefit. Given that I was already running that much advance, we decided to be safe.
Bashing an Authorized Vendor such as CP-E is unacceptable on Mazda Forums.
Note the following site rule:
9. Vendor and merchant disputes from customers must be handled privately. Negative reviews for vendors can only be posted after (a) direct communication to the vendor has failed, and (b) you have contacted a forum administrator or super moderator explaining the situation and have gained permission to post a negative review. Personal attacks towards a merchant or vendor authorized to do business on the forums is strictly prohibited. Mazda Forums has a zero tolerance policy towards unwarranted attacks on vendors and merchants (users with the title "Authorized Vendor" or "Authorized Merchant Member" under their username). They are the "lifeline" of the Mazda aftermarket. Making unwarranted attacks, or negative reviews without proper permission, against vendors or merchants can result in an immediate and permanent ban without warning.
I will enforce this rule if I see anymore CP-E bashing on Mazda Forums.
Thank you for your understanding and cooperation in this matter.
Status
