Corksport sway bar comes with new brackets... Are they good enough?
Jester7677
Corksport sway bar comes with new brackets... Are they good enough? If not, what else is needed? Also, what is the consensus on which setting to run on the bar?
Thanks!
Sent from my iPad using Tapatalk HD
They should be. I'm running hotchkiss brackets of the same style on mine. At the time they came with generic oem style brackets that were bending. I run mine on two but i also have adjustable links.
On two, as in max stiffness setting? Is it too much, did you try 85% and was that too little?
Chris, what is your opinion about the end links, with a 3-1/4" drop? I would need to replace them, with adjustable ones?
