CorkSport SRI help
DiegoRF
Mazda 2
well, I am about to install it one of these days but I have a cuestion about the double ended barbed fitting, The photo says it all, is this ok? cause i try to push it hard but I cant. and neither can take it off.
SHOuld be fine unless you're super concerned about cosmetics. If it wont move in or out it's probably got a pretty solid seal. I had difficulty with that fitting too.
I have installed it already, but I used the stock hoses because I dont know how to put that little circuncerence from the corksport hoses on the bigger stock ones, what can i use, options? Im newly.
I used my stock hoses too. It's been a couple thousand miles now and everything is perfect.
I had a similar problem with the barbed fitting, but was able to twist and push it enough to eventually get it all the way seated. It was a freakin' b*tch though. As for the other CS supplied hoses, I couldn't for the life of me get those damn hoses on anything, but then when I called Corksport out of pure desperation, Derrick told me to chew hard on the end of the hose (I used my molars) for a few seconds and try it again. It worked like a charm - they didn't go on "easy" per se, but it was then at least possible to get them on to all the places they were supposed to go.
i had the same issues.. i had to call corksport to ask. In the end, i used a little bit of wd40 and it helped A LOT at getting the hoses on. any auto store will have a lube for the hoses.. i learned too late. I asked if I could reuse the factory hoses instead of the supplied ones and they said they didnt see why not. You should be fine.
