Cooling fan assembly help! 2003 MSP
Michalah
2003 Mazda Protege Mazdaspeed
I bought a 2003 MSP and they had installed a much too small radiator and fan in it. I replaced the radiator with a Nissen radiator that fits perfectly, but I can't figure out what fan assembly fits. I bought the Mishimoto (http://www.autopartswarehouse.com/s...3/Mazdaspeed/4_Cyl_2-dot-0L/MISMMFSPRO03.html) and it is too big, probably fits the non-turboed model. I can't find many resources about what fan assembly is supposed to fit in the MSP. So what fan assembly do I need??? This is my radiator: http://www.autopartswarehouse.com/s.../Mazdaspeed/4_Cyl_2-dot-0L/W0133-1759622.html
Do you have the stock fans? The mishimoto setup works for the regular protege rad but not the MSP short radiator. If you upgrade to a front mount intercooler you can install a full size radiator and run the mishi shroud if you like. The stock MSP fans will fit on your rad, or you can modify regular pro fans if you find some from a junkyard. OR you could buy a pair of slim fans and install them on the radiator with the plastic ties they include with them.
