I am not for sure tbh, I took it in to have the recall fixed something with a heating valve and the oil change done and not even a week later I start over heating and take it back and they say it either a blown head gasket or cracked head but can't tell me which unless they take it apart and don't want to do tht bc it will cost me more money... so they just want to put a used engine in altogetherSorry to hear that, and hope you somehow find a way to resolve the problem with minimum loss. Yes you should come here before you made the purchase, and read the related discussions. This cracked head problem usually won’t be reflected by usual reliability stats such as Consumer Reports, but once it happens, it’d cost an arm and a leg to fix it unless you can DIY on such task.
BTW, the related TSB claimed the cylinder head has been updated since MY 2021 for the 2.5T where the cracked head symptom is coolant leak. OTOH, the cracked head on the 2.5L NA with cylinder deactivation has symptom of oil leak, and Mazda has never updated the cylinder head since the engine came out in 2018 MY. This thread and class action lawsuit is only for the 2.5T. Since you have a 2021 CX-5, can you verify what kind of engine do you have, a 2.5T or a 2.5L NA with CD? And how many miles on it?
I had a close friend also look and coolant is visible so I'm assuming has to do with mazda not taking care of the problem
