Code P0451 and CG36-42-580A - Evap hose and FTP sensor assembly
Using BlueDriver I obtained Code P0451 EVAP. It appears that the fix may be replacement of the evaporative hose assembly, part CG36-42-580A with FTP sensor and the short cord, part L5E1-18-791A. Has anyone here replaced the evaporative hose assembly? The link below shows the part.
One end is connected to the fuel tank. I assume there is no fuel that leaks out when this end is disconnected? How are these green clips removed? Looking for guidance/instruction on how to replace this assemble. Some detail on removing both ends and the attachment with skinny hose that runs from the FTP sensor.
Thank you!
