I read some wonderful news on the Cobb forum that they are currently testing additional tables for ATR, which will be Calc. Load A & B, which will allow for accurate fueling beyond the cap. It appears you will be able to request a load beyond your cap (different between cars/climates), and will be logged as a % of requested load. I personally am super geeked about this, because I clip my load cap @17psi! Get excited ladies and gents. I'm already daydreaming about 3 things that these additional tables will provide me:
1. Proper MAF scaling (currently scaled down to try to stay under cap)
2. Correct AFR under high boost (currently gets lean with initial boost, and then gets too rich in upper rpm's, all due to clipped load cap)
3. 23psi (AFR's not desirable beyond 17psi without the MAF/commanded eq trick, which is effective but sketchy! I want booooooooooost!)
Me thinks this will help push AP guys to that 400whp mark so we can go out and play with the SB folk
