cobb AP question....
jracer
ok.. i have read lots of info on the forums.. but alittle overwelmed..
since i am new to the speed6 and turbo cars..
my speed6 has a cobb SRI, forge BVP and magnaflow cat back exhaust..
we do have 93 oct gas in florida...
so with the Cobb AP.. how much power increase should you see and does it open the throttle all the way ?? its my daily driver and while i would like more power still wanna be safe with the tune..will it couse knock also ?? i dont really plan on doing anymore tuning.. just looking for alittle more fun !!
and i will be able to "flash it back to stock " for dealer correct ??
thanks guys....
john-
You can go to http://www.mzdspd.com/mzdspd/default.aspx and download a Stage 2 93 octane map. I put this map on a friends car and the gains were pretty noticeable. Yes the TB will stay open all the way to redline. The best thing to do if you have to take it to the dealer is uninstall it which is pretty easy.
Your more like Stage 1+SF93. Stage 2 if you have a downpipe. Ive had a lot better LTFT's with the 91 map. Like MR X said it can be uninstalled for dealer visits but requires you to save the sock map which takes 30 minutes. Knock will still be present but no more than stock.
