Sorry to revive the thread!
Sorry to revive and old one, I hate doing that, but rather than cluttering the board with new stuff... I searched the P5 forums and really never found a definitive answer on this.
Mine also pops out when I pull something out. I pulled it out to see how the thing was wired in back in case I ever wanted to do something with it, and when I tried to get it back in, it just doesn't sit in there securely anymore, and pops out everytime I pull out an adapter.
The adapter I have is a bit big, but, this never happened before. Anyone found a solution to this OTHER than using epoxy? I'm concerned that if I use an epoxy, like Krazy Glue, the socket will be stuck in there for good...
I'm thinking of going into the right side of the panel on the lower dash to see if I can't PULL the socket into place a bit tigher...but I don't know if that's the right panel to pull and how to pull it (the one with the single screw on the right side of the floor just in front of the parking brake and below the lighter socket)
Help? (help)
