Hi guys, I'm new here as you can see and I have a bit of a problem. I bought a 2006 Mazda 5 GS in November 2010 and the check engine light came on. The problem is that the engine power is kind of cut off. The engine idle fine but as soon as I hit the accelerator there is no power. I nursed it home and checked out the fluid levels in case there was some sort of "engine protect" module. (I had this on my 2001 volvo v70) which I traded for this Mazda. When I started it back up, the problem was gone but the light stayed on for about 3 days then went out. Yesterday the same thing happened, check engine , no power. Thought there might be water in fuel so I went to the service station and tanked up adding some gas line antifreeze. As soon as I restarted the car...no more problem but the light is still on. I have a 2.3 litre in this one. I read on some other forum that there were problems with a speed controller...I dunno...I'm stumped. I took mechanics in school but cars in 1982 were alot easier to work on than today. Any help would be appreciated.
Thanks in advance.
Thanks in advance.
