Hey everyone. I just purchased a cx-9 touring. I noticed it has a aux and power outlet in the center console, however I've tried 3 plugs and can't seem to get any power. All other power seems to be working fine.
It only works with car running I believe. Did you have the ignition on or off?
Sent from my iPad using Tapatalk
Have you considered try a different charger?Yea I have the car on or off and it doesn't seem to function. Time to take apart?
My gt only have one in the passenger side. On the center console I have 2x usb ports.Have you considered try a different charger?
In my previous CX9, I remember having a phone charger that worked fine on the front sockets, but did not fit well on the console socket, was a bit too short to make the right contacts on at the far end inside the socket
In the other hand, I was not aware that there was a socket on the central console. on My GT I only see 1 on the front Passenger side, and is a bit tricky to use it
Note that Joshrp5 has a 2010 CX-9, NOT a 2016 as owned by many who have replied.
I had a 2011 and had no issues with the console socket.
I agree that the charger may not be making contact with the center contact.
If checked with a voltage tester and the socket is actually not working, I'd first suspect a fuse.
Have you checked the fuse?
Gee, I wish I'd thought to suggest that! (ohsnap!)![]()
Mine worked from the get go without having to do anything. If everything in the car seems fine, I would bring it in to the dealer to have it checked out. Perhaps a fuse?
Pardon me for not thoroughly reading all responses before trying to help the OP. I'll make sure to defer to your expertise and original suggestion next time--because internet forums never contain repetitive and duplicative posts or threads. (bowdown) Sheesh.Note that Joshrp5 has a 2010 CX-9, NOT a 2016 as owned by many who have replied.
I just get frustrated when people on a different car forum (where I'm far more active) post a comment similar to if not exactly the same as the one that came before.
