BlueBeast22
- 2000 Honda s2000 ap1
Ok, since I've been modding my MSP about 2 years ago I have noticed abnormal boost issues. Sometimes the car boosted quicker than other times, and I just brushed it off as it being a bad WGA or my MBC. I have the hiboost FMIC, Injen CAI, 3inch Apexr1 Jpipe back exhaust + other mods. But I just recently got sick of the stock WGA since I thought it was bad and changed it with the ATP 6psi WGA. Now it just seems that my boost isnt boosting as quick as it should. (with the stock WGA it would sometimes boost quickly and sometimes the same way its boosting now)
Here is an example... I talked to my friend who used to own a black MSP with pretty much the same mods. If he was say in 2nd or 3rd gear at 2k rpm and floors it his boost would quickly be at 10psi at around 3k RPM's where he had it set. Me? nope... my boost just stays at 1-2psi and SLOWLY climbs to 8-9 untill like 6000 RPM's. Now maybe his boost controller was the reason why but still im currently not running anything and it still feels like it should be boosting when its not. I dont believe its a boost leak because when its at full boost it holds boost which in my case its 9psi with no MBC. I also know its not a vaccume leak because im constantly reading 24 vac under normal idle. I have changed out alot of my hoses with silicone, and I ziptied them to make sure they dont leak.
One more thing, I have noticed that the needle in the boost gauge will shake irradically(sp?) and not smooth like it should be and it will eventually settle down at the proper psi(9) I figured it might just be my gauge but I tried another gauge and it did the same. I dont ever remember the gauge acting this way untill I put in my FMIC. Anyways all im looking for is any advice from anyone who has had this issue or knows what could be causing it.
