Can anyone in the Dallas/Fort Worth area perform a used engine swap for me?
I have a 2015 Mazda CX-9 with blown water pump. Looks like the cost of this is extreme with timing chain, belt, labor, etc.
I'm thinking it might be best to simply perform an engine swap and plug in a new timing chain and water pump at that time. Thoughts?
Anyone in the DFW area who has a shop and interested in this work?
Yes, another engine would be better than rebuilding it. Maybe not worth the trouble unless it's low miles or perfect body/interior. The caveat is you cannot be 100% certain that the replacement junkyard engine is better than the one you have. A good mechanic would test the new engine for compression and leak down tests before taking the time to install it.
