akhilleus said:
Well that is interesting. However there is not ecu in existance that isnt overriden by our ecu. Second wouldnt the j-spec engine have a similar af management as the aspec....if not why cant we buy one. Also there are people on these boards with HC pistons...Couldnt i just run high octane fuel. Anyway i dont see how u could have detonation since the compression isnt as high as some turbos out there...some of which arent realy managed either....Also this is the first time i have heard this regarding HC pistons and i doubt that without proper management i would only net 3-5whp
I think you need to research this heavily regardless of what you do...First of all yes there are engine controllers that 100% override the stock ECU, being that they actually 100% replace it other than a few stock sensors...An E-manage only controls fuel maps, and it will work with an FS-DE's ECU, however eveything I have heard about them is that they are good for mild boost setups at best...They are notoriously inaccurate and offer no control of ignition timing...No good for HC...The probelm with our ECU is the Open Loop AND Closed Loop...most piggybacks work with one or the other...there are only a few that work with both...Our ECU runs on open loop at partial throttle positions and uses various sensors to determine fuel/timing requirements...at WOT the system switches to closed loop in which preset fuel maps are used...Our ecu overrides everything becuase all chips and most piggybacks simply change the sensors voltage readings in order to confuse the ECU into thinking there is a difference and in turn lean out the mixture slightly to make more power...Our ECU does not give a s*** what any of the sensors are reading at WOT becuase it is using only the preset maps...there are currently 3 available piggybacks that I know of that operate in both modes, again look up Terry's posts for info on them...
Second the J-spec ECU for the ZE is OBD-I, your engine being OBD-II...The price of converting your protege back to OBD-I would be probably the same as a Haltech E6x or more ($1100 plus installation), and you would not have any of the programmable features...
I am confused by what you posted a little...mild turbocharging is possible with the stock ECU becuase the ignition timing more or less does not need to be changed...as long as you have plenty of fuel to buffer the internal temperatures, you won't run lean and you won't have detonation...Then a system such as a E-manage allows you to map in more fuel for higher boost.. the need for the timing still isn't needed as much, again as long as the boost is below 10psi or so...Talk to Terry about that, he knows his s*** about turbo's, I do not...
Now High compression pistons are completely different all though they do a similar thing...the increase compression physically squeezes the fuel/air mixture tighter before ignition, raising expansion rates after ignition and thus creating more power from the same amount of fuel and air...But here is the bad part...with the increased compression, combustion chamber heat becomes ridiculous and since the pistons are dimensionally different and internal pressure changes, optimum ignition points change...So you need an engine controller that can change timing, and fuel maps...the increased heat usually requires more fuel as a buffer (like boosted engines) to keep detonation at bay by richening the fuel/air mixture (too high of internal engine conditions can cause detonation by 1. the mixture can ignite without the spark, 2. the mixture can expand too quickly, 3. the mixture can light on two flame points, creating a colliding explosion that usually turns your spark plugs into Anti-Aircraft projectiles..j/k, but it wrecks the engine very quickly)...all of those can cause knocking and pinging...
so a standalone is a must for high compression to this degree...You will have detonation with any of the J-spec pistons on an otherwise stock FS-DE and ECU...and I think 2-5whp would be on the optimistic side...you could probably loose power...
If 30+whp was available with a $200 set of ZE pistons everyone and their dentist would do it...
