Bumper thread
RallyeRedSi
2008 Civic Si
anybody have the how too to remove the front bumpe ror the digram thread i tried searching for it bu tcouldn't find it
there are 2 screws when u open the hood, they have a fat head on the, very flat looking, remove them, then in each wheel well remove the screws and plastic clips that hold the splashguard to the bumper. then crawl under the car, there are about 6-8 screws that have an 8mm head on it as well as phillips, remove them and then you should feel the bumper begin to flex somehwat from the bottom. once all of it is loose, u will need to kinda tug from the top center, as there are 2 black plastic clips that hold the bumper into the core support. that should do the trick.
