so I talked about starting a build before and we have commenced. the protg will soon be twin charged. h-beam pauter rods, supra pistons skirt machined to clear for rotation, and block .40 over, the super charger lines up to the pullys perfectly with some custom work to mani and a custom spacer/mount. the charger was on my buddies mx6, supercharger is 8psi and until the build is complete Ill then share the supercharger and supra pistons part numbers. ill give the specs on everypart that has to be customized, no more turbo lag off the line. lets see how this goes. ill update with pictures weekly once the block gets back, pistons and spacer chunk for manifold charger bracket. The machine shop in Miami is backed up about 30 days.
