@sinistriel@ Thank you for your great video. I found and tried it because I have a rather strange issue (it's not really a problem, but I find it kind of weird) with my CX-5 2.5 G-194 AWD AT 2020, Europe, non-turbo, 70.000km. On the highway, once it is warm (during winter, it takes longer until it happens), every like 2-3 minutes the RPMs go 2-300RPMs higher for like 5s in the 6th gear, and then fall back to normal, lacking any comprehensible reason. The highway is completely flat for dozens of kilometers, it even happens while driving downhill. There are no strong winds, there is no other traffic. It happens with and without Cruise Control, also in M mode, with A/C off, iStop off, etc. etc. Mazda dealer has never heard about it, can't really find anything but didn't really believe me I think. He made a short test cruise not on the highway changing through gears and said there is minimal slippage on the clutch, but it's okay. There are no error codes, so he could not do more. Don't think that was really a relevant test, because I don't have constant issue, but a recurrent one under circumstances he didn't have time for.
I made a video some months ago for a European forum, nobody here has heard about it before and nobody really has a clue:
youtu.be
I can't really find anything similar to my issue. Am I the only monk noticing that? I don't really find that behaviour normal. You can also feel a short jerk in the powertrain. First I thought about Cylinder Deactivation, I can also feel a short jerk with CD, but I think the parameters are not fulfilled for CD on a highway.
Since my video, I added OBD and forscan to the mix. I found that the TCM slip value is very high during those events, the android app crashed when I stopped my car, so I couldn't save the data and look at the other TCM values. I have to repeat it. Most likely, I might find what I was suspecting for a long time: The torque converter lockup-clutch (I mean the clutch that bypasses the torque converter when a fixed transmission of force is required and possible) opens up, causing slippage. But why, for gods sake, every couple of minutes? What is it still trying to measure or learn?
I thought maybe resetting the learned values might help and found your video. It worked fined at first try, motor revving up in the end. I noticed a sudden difference in the TCM's actions, but the issue with frequently increased RPMs in 6th gear stayed the same. On the other hand, it how has to learn again, but I would be amazed if it stops that annoying behaviour in the near future.
Do you have any idea why the TCM is doing what it is doing? Ever heard about such strange issues with Mazda ATs?
