Best way to put on window stickers??
BC3I
Contributor
2004 | Mazda 3i
ok i am trying to figure out the best way to put window stickers on with out getting air bubbles....any suggestions???
Well I have put window stickers on many a time and I just clean with windex very well. Then start on one end stick it down and use something flat but kinda solid to press it down. Go over the whole sticker a few times till your sure its on good and most of it should be good. Sometimes you just get a few bubbles but you can take a pin and pop the major ones, the small ones usually come out after it sits a few days in the sun. The heat takes the air out of them and it will sit flat.
if it is vinyl type you can use a solution of like 15%dish soap and the rest water in a spray bottle.... after cleaning the window spray this mixture on the window and apply the sticker......this will allow you to move it around and get it exactly where you want it. then once it is set take a credit card and rub all the water out. then remove the backing tape off the vinyl and finish rubbing it out......this leaves no bubbles and it is positioned exactly where you want it
