by 'uninvolved', i mean 'easily removed'. take that as you will.
the ones that i would figure in are:
-intake (SRI)
-bypass valve
-test pipe (not too easily removed, but doable if you're good w/ tools)
-TMIC (same as test pipe)
-cobb accessport
anything else?
also, cobb says that its s/w is not compatible in applications that use other intakes - has anyone tried other intakes with good results? i'm guessing they're being cautious and also indirectly promoting their SF intake, but that sucker is out of stock for quite awhile.
lemme know if you've got ideas
i know that basic mods are frequently discussed, but i'm hoping for advice from ppl w/ personal experience with as many of the aforementioned mods as possible.
-intake (SRI)
-bypass valve
-cobb accessport
anything else?
