A AZDriftR Member : 1991 323, 1987 BMW 535i, 1988 BMW 325is Sep 28, 2003 #1 what would be the easiest way to relacate the battery to the trunk i.e. wiring and a new platform for the battery..
A AustinG Sep 29, 2003 #2 WHY WOULD YOU? the car is pretty balanced already, that's the only main reason you would do that.
J jared Member Contributor Sep 29, 2003 #3 AustinG said: WHY WOULD YOU? the car is pretty balanced already, that's the only main reason you would do that. Click to expand... for balance. proteges have a 60/40 f/r weight dist. so, moving the battery to the rear is a good thing to do. AZDriftR: try here http://store.summitracing.com/section.asp?d=11&s=14 you can get kits elsewhere, but that should be a good starting point.
1 1sty Member Contributor : 2006 Toyota Tundra DC Sep 29, 2003 #4 If you ever, EVER, even think about putting in a door speaker amplifier in the car then don't do this. You will have more engine noise in the system then can possibly be filtered out.
A AZDriftR Member : 1991 323, 1987 BMW 535i, 1988 BMW 325is Sep 30, 2003 #5 thanx jared, and 1sty i dont think im going to be putting in and speakers but thanx for the warning...
