I've just finished installing my 19mm AWR rear sway-bar and end-links (on a side note, the drunken idiot of an engineer that designed our stock end links could easily be replaced by a monkey, with little impact on the quality of his or her work). I noticed in a quick "AWR" search that other members have been positioning their new upper end-links on the inner sides of their rear strut mounting tabs. When I assembled my sway-bar end-links and attached them to the strut tabs, I seemed to be left with better control arm clearance when I mounted them on the outer side of the strut tab. Has any-one else positioned their end-links this way? I like the extra clearance but if I'm getting it at the cost of screwing-up something else I can do without it.
