Apex springs????
Leafster
I'm looking at switching from coil-overs to springs. Has anyone used the Apex springs? Apparently they are 1.7" drop. The distributor that I deal with carries Apex, Eibach, and B&G. I have heard good things about Eibach, but I want to go as low as I can and have had with the coil-overs. The tech guy at the distributor says that the Apex has a lower spring rate, so softer ride and better match to the factory damping rates. Has anyone used them? Or something else which goes pretty low?
