to those with pr5s that have bought aftermarket speakers and are amplied. I was wondering how you routed new wires from the amp to the speaker? did you have to drill holes?
right now i am deciding weather or not to buy a new amp, this is what i have already
Pioneer DEH6400 HU
Clarion 5x7 SRC5794 for the fronts
rear speakers are stock
dual Clarion 10" subs pwr by Clarion APX401.2
Clarion APX401.4
New Heat Sink Design
Maximum Power Output 400W
Continuous Average Power Output 200W (50W x 4 into 4 Ohms 20Hz-20kHz @0.05% THD)
Typical 2-Ohm Stereo 90W x 4 @ 0.5% THD
Typical Bridged Power 1kHz 190W x 2 @ 0.5% THD
Bass Extender Control 0~18dB @ 45Hz
Adjustable 55Hz-5.5kHz, 12dB/oct. High/Low Pass Crossover
Mixed-Mode Operation
Bridgeable 4/3/2 Channel Operation
Speaker Level Inputs
Double-Sided Glass Epoxy Circuit Board
Clarion APX201.2
Maximum Power Output 200W
Continuous Average Power Output 100W (50W x 2 into 4 Ohms 20Hz-20kHz @0.05% THD)
Typical 2-Ohm Stereo 110W x 2 @ 0.5% THD
Typical Bridged Power 1kHz 230W @ 0.5% THD
Clarion SRR1684 6 1/2" Coaxial Speaker (PAIR)
6 1/2" Metal Coated Mica Injected Polypropylene Woofer
Gyro Imaging Angled Pivoting Tweeter
Rubber Surround
Strontium Magnet
1/2" Balanced Drive PEI Tweeter w/Neodymium Magnet
Built-in GM 6.5" Adapter
Heat-Resistant Kapton Voice Coil
160 Watt Maximum Music Power
Clarion SRC5794 5" x 7" / 6" x 8" 2-Way Plate Speaker (PAIR)
5" Metal Coated Mica Injected Polypropylene Woofer
Rubber Surround
Strontium Magnet
130 Watt Maximum Music Power
Pioneer DEH6400 HU
Clarion APX401.4
Clarion APX201.2
Rubber Surround
Strontium Magnet
Rubber Surround
Strontium Magnet
