Hi,
I've been through a lot with my Protege,
I thought that you owned a Protege5.
What protégé do you have and what year is it.
Mazdas haven't used a distributor for a LONG time.
I think my 83' GLC even had electronic ignition?
Hi,
This hasn't occurred again, maybe the change of the fuse box did help somewhat...The car stills stalls randomly but I noticed that sometimes when trying to re-start it a buzz comes from the cooler fan relay
After reading more about USA Proteges and comparing them to mine, I don't have an EGR per se but I do have a Canister w/ a Canister vent valve solenoid. I think I didn't mention it, but this solenoid was broken. I replaced it a few days ago with the fuel regulator and adjusted the injectors' rail.EGR solenoid
So far this is still disconnected, ordered a replacement that should arrive tomorrow. Inspecting again the old wiring the + cable seemed like it was rubbing somewhere. If this doesn't solve my problem I might end up buying the ECU or some scanner firstDecided to check once again grounds and found the neutral safety switch kind of lose, and ended with both cables detaching from it.
