Order direct for fast, free shipping!
JBR Under Mounted FMIC Piping Kit
Routing the piping beneath the motor reduces the amount of hot side charge piping by 12-16% when compared to other kits on the market. Reducing the amount of piping decreases turbo spool up time, reduces boost temperatures and makes for an impressive, sleeper looking engine bay.
JBR FMIC Piping Kit
The OEM top mount intercooler is sufficient for stock horsepower but, for those wanting to make more, it simply isn't capable of providing the cooling capacity necessary. To make more power, the OEM top mounted intercooler needs to be removed and replaced with a larger front mounted intercooler. This JBR kit makes that possible.
This JBR kit is designed to fit all clocked OEM/BNR and most big turbo setups. It is constructed from mandrel bent 6061 aluminum piping and 7 layer high-strength thick walled silicone couplers. All of which are tucked neatly above the belly pan.
JBR FMIC Cold Side Piping Kit
Upon exiting the intercooler, the cool boost air enters the JBR one-piece, high strength, thick walled silicone hose and travels from there all the way to the intake manifold. Silicone has a very low heat transfer coefficient so, the hot ambient air in and around the engine bay will not be able to penetrate through all of the layers of silicone therefore, the cold air you just spent $800 to get cool, will stay cool!
Applications: 2007-2013 Mazdaspeed 3
JBR FMIC Piping Kit
