MikeHTally
- 2008.5 Speed3, 2006 Chrysler 300C, 2003 Ram 1500
Both fuses and the relay are healthy, the compressor just doesn't turn. Guess it's time for a dealer visit.
omg im sure i won't be thinking about AC for another 4 or 5 months!
but seriously...how do you know that the relay is ok? fuses are kinda obvious, but relays can be kind of tricky.
if you have a multimeter you could find out for sure if it's an electrical problem
Unlikely it's a rock hit - the belly pan's under the compressor.it is likely you have a hole in the condensor and all the freon leaked out. I have had mine replaced twice already. they are in a bad place with no protection and take alot of rock hits..
As a matter of fact, I've already gotten it back from the dealer with a new compressor and drier. No fight to it. Overnighted the parts, in the shop just over a day.They're not going to replace the compressor just because you're low on refrigerant. They'll dye it up and look for leaks. If it is in fact a pinhole in the front of the condenser, they won't cover it without a fight.
