OK friday night i did my typical routine work, gym, then home. I got ready to go out and left my house about a 1/4 mile don the street my car felt like sh*t. It wouldnt turn right, it was sloppy like a tire was flat. So i pulled over and got out:
I walked aroung to the back of the car and found the passenger rear tire flat i ran my hand around the tire to see what happened and the metal from inside the tire stuck into my fingers. This was odd(no sh*t). So i got my flashlight and looked at the tires from under the rear end. I saw that both of the inside of the rear tires were worn right through tire and metal.
After changing the flat one i noticed that the wear happened at an angle (like a camber problem) it was worn to about 75% of the contact area. The outside of the tire still looked fine so it was unnoticable from a simple glance.
This is a serious problem and i hope its not a common one but i need everyone to check if they have anything similar to this.
I have 9000 miles on the car and had the rims off to clean them 2000 miles ago. During the last 2000 miles the only real change was the weather getting alot colder. Maybe these tires cant handle the cold but i cant explain it. Its going to the dealership on Monday.
Please respond
thanks
Please respond
thanks
