A couple of CAM queston
Sonny
When changing CAMS do you have to change both the intake and exhaust cam? If so where can I find them? The only one I've seen were the MAZDASPEED cam on SR Motorsports.
You can change one at a time.
Corksport has them.
I beleve you can actualy order mazda speed cams through your dealer.
Look into the wagner cames they gain 26hp.
you can order one, not both, of the cams. the wagner cams have yet to be independently dyno proven.
I only know of two people that have ordered and recieved their Wagner cam, me being one of them. DaveB also received a set, I believe.
I don't know if I'll be able to get them installed anytime soon. So if you want a pair without the 6 month wait, PM me.
Hey you weiner... put 'em in! Or in my car (cheers)
Corksport has them.
There isn't any mod for the FS-DE that gives you anywhere close to 26hp without resorting to power adders(boost or nitrous). Good cams, tuned properly will give you 10-15whp when optimized with headwork and higher compression.
Thanks for eveyones input. SR motorsports has the mazdaspeed cams and they say 18HP increase, 10 from the intake and 8 from the exhaust. How true is that?
Nobody has made 18hp from cams in any Mazda 4 cyl.
