imjustagirl said:I work for a dealer, trust me dont take it to one for the 30k or you're going to get ripped off...![]()
for the 30k on my P5, all I did was change the plugs, air filter, drain and fill the coolant and rotate and balane the tires.... it seems like your pads wore out early, i have 60k on mine and havent had to replace either set... all you really need to do is change the plugs, airfilter, drain and fill the coolant and trans fluid...![]()
MaraUCSD said:The tires are OK for dry pavement, but getting too low to for winter driving. The pads are also getting low, and I would rather spend the $20 on pads now rather than have to resurface my rotors later.
I will check out changing the tranny fluid too. I finally will have some time off of work to do this stuff before winter, so I figured I would go ahead and do it.
