Hi everyone,
Sorry English writing is not my strongest skill.
Rough day today. Spent my afternoon detailing the 2019 CX-9 (bought at Nov 2018 now 37k miles just passed warranty) and in the end the car wouldn't start. Everything was normal before the wash. It was throwing a bunch of malfunctions including SCBS/Keyless System/Cameras/Sensors etc I couldn't remember all (And one says Refill the tank but I have 4/5 full tank). Basically most of the dashboard was lighted up. It did try to crank for half a sec and stopped. I used Torque Pro app and BT ODB2 adapter and no fault code found. I'm suspecting the battery is dead but car is only less than 2.5 years old. We do daily 40 minutes each way commute and some short trips.
Here's the list of my diagnosis I've tried / things I did / possibilities.
- Fortin Evo-One with Maz3 harness was installed 2 days ago by myself and was working flawlessly. Disconnected the harness and restored to factory set up still no go.
- I placed the key fob in the cup holder with the car off for the duration of my wash which was about 3-4 hours this afternoon. Was about 50'F nice weather.
- Inspected the fuses in the panel all looked good.
- I used damp cloth to wipe down under the hood briefly. It was normal routine I do for car wash all the time.
- Cleaned and put back cabin filter and air filter.
- Tried both key fob and replaced both key fob batteries. At one point Low Key fob battery warning was displayed.
- Disconnected battery (-) terminal and waited an hour. Reconnected, locked then unlocked the car with remote. Get in the car still get Keyless System Malfunction and couldn't start.
- I have a dashcam plugged into the passenger footwell usb. Been using it this way since new and no issue.
- Accidentally engaged the ebrake during interior cleaning and left it on.
- Brake feels super firm but brake light does lit up.
- Honk doesn't work.
- Ebrake light was flashing sometimes.
- Could not open the tail lift gate with like double beep.
- Sprayed the underside of the car to clean off dirt and salt.
- Serviced at dealership last month / 1000 miles ago and the battery status on their report was green.
Now about 6 hours later I tried to start it again it won't even crank. And some new weird things like Door button wouldn't work, mirror doesn't fold, remote sometimes work sometimes not. Had to use physical key to lock the car once.
Like I said I'm suspecting the battery is dead. Could it be the ~2 hours i was cleaning the interior and keep having the doors open and close with the key fob in the cup holder cause the dome lights to drain my battery? Or could it be the Fortin Evo-One draining? I don't have a battery tender/charger or multi-meter nor I couldn't try to jump start with the car head in my narrow driveway. My best bet is to take the battery to Autozone for testing. If the battery is indeed dead I will get a Duralast Platinum (or any recommendation?) and see if it will fix it. My last option is tow it to the nearest dealership if changing battery doesn't help.
Could I have damaged the electrical system during my car wash? I've been wash the same way for years with my past BMW and this CX9.
TLDR: Car won't start and throwing dozens of malfunction messages after routine car wash by myself. Suspecting the battery and seeking advice.
