2018 CX-5 Door handle issue...Help
So I locked the keyfob in the car .. (I guess the battery was low , sitting in cupholder?) well went and got the slimjim thinking I could get it open ..no luck called pop a lock ..
anyways now the driver side door wont open using the handle from outside .. I can open with inside handle ..has anyone taken the door panel off to fix handle issues ? not sure where to start
You'll probably have toremove the interior door panel. It might be something simple.
Have you ever removed the door panels (for new speakers, etc)?
Upvote 0
Here's the manual section for removing the door panel. You can then check if (likely) something is disconnected from the handle.
Upvote 0
