My partner has a 2016 Mazda cx5 touring AWD with about 100k miles on the car. I did an oil change at 93k miles and just did another at 100k. I did a transmission drain and fill at 93k with an oil change. I filled it with a full 5qt container and did another oil change and transmission drain and fill now. (Wasn’t sure if any drain and fill was done before so decided to just do another one now.)
Anyways the problem is that I measured the amount of oil coming out this oil change noticed only about 3qts of oil came out. Is this amount of burn normal? The oil was pretty sludgy. We used penzoil ultra platinum 0-20. Decided to go with Mobil 1 extended performance 0-20 for this round. Thinking of doing another oil change at 5k miles next time.
