2010 CX-9 P0016 code
Recently had the check engine light come on, scan shows P0016. I checked the camshaft position sensor and it's reading 1.2 ohms. Not sure where else to go with it. Seems to be running a little rough intermittently with some noise but nothing crazy other than that. Appreciate any tips.
2010 CX-9 GT
Check your oil, make sure it isn't contaminated with water.
If that isn't it, the variable valve timing actuators have been known to fail occasionally, which causes this issue.
Upvote 0
