2007 MS3 alignement spec
mcb
Hi guys! I wonder if someone have the stock alignment specs?
I'm thinking about re-align it to give it some camber and toe out for auto-x puropse.
ok i got what i wanted, i'll post it for the benefit of everyone:
NOTE: since i cant find the degree sign on my keyboard i will use * as a degree sign.
Front:
Max steering angle: inner 36*00'
outer 30*12'
total toe-in with tire 2mm(0,08in) tolerence4mm(0,16in)
Inner rim 1mm3mm(0,04in0,12in)
in degree 0*11'0*22'
Caster angle with the tank full of gas 3*08'(tolerance 1 degree)
Camber angle with a full tank of gas -0*57'(tolerance 1 degree)
Steering axis inclination (reference) still with full tank 14*21'
Rear:
Camber angle with a full tank of gas -1*42'(tolerance 1 degree)
Trust angle (reference) still with full tank 0* (tolerance 0*48')
I hope everything is clear. Those data come from factory datasheet.
A little different from the regular 3
I was surfing and found that the finishline website has the instruction manuals for most accesories and mazdaspeed parts online. The attached is a copy of the alignment specs for a Mazda 3 with the Mazdaspeed coilover kit installed. I thought it would be the same but it is not.
Just some information for those that want it.
Cheers
Peter
Mazdaspeed Alignment Specs
Ok, I got bored - I like things orderly so I took the Mazda layout and applied mcb's numbers with a little interpolation for different gas gauge indications.
If I made a mistake - let me know - I'll fix it.
Cheers!
Peter
i got the sheet from shop manual and its not the same as the standard 3. I checked pmeilakjr number and they seem pretty accurate. I dont have the sheet with me so i cant tell for sure. I'll come back to you soon.
