2006 Subaru Imprezza S204
quagmire
As its predecessors S202 and S203, the new Impreza S204 will only be available in Japan. This special edition model will be limited to 600 examples, and each of them will cost about five milion japanese yen (approx. $40,000) when it debuts on January 13th.
The modifications include a reprogrammed ECU, new pistons, crankshaft, exhaust and an upgraded turbocharger. This helps the S204' 2-liter engine to 320 bhp and 319 lb-ft of torque.
The Impreza S204 shaves off 13 lbs with lighter BBS wheels. A stiffer suspension lowers the car by about half an inch.
The interior differentiates from the standard Impreza WRX STi by an exclusive steering wheel, aluminum inserts with engraved serial number and Recaro bucket seats.
The customers will be able to choose between three colors: WRC blue, grey and black.
Engine:
Type: Flat-4, Turbocharged
Displacement cu in (cc): 122 (1994)
Power bhp (kW) at RPM: 320(235) / 6400
Torque lb-ft (Nm) at RPM: 319(432) / 4400
Redline at RPM: n.a.
Brakes & Tires:
Brakes F/R: ABS, vented disc/disc
Tires F-R: R18
Driveline: All Wheel Drive
Exterior Dimensions & Weight:
Length Width Height in: 174.5 67.9 55
Weight lb (kg): 3196 (1450)
