2.3 magnetic drain plug
06 MS6/03.5 MSP
im about to do an oil change on my ms6...wondering if anyone knows of a magnetic drain plug made for the 2.3 specifically yet? and if no one knows that than does anyone know what thread size the plug may be? called a few parts stores and they didn't know. and unfortunatley the dealership isn't open today (sunday). thanks
bombermanx said:
ebay is your friend.
It's kinda funny that we don't have one already when my 1984 Nissan pickup has no less than 5 of them...engine, tranny, trans. case, and both axles., but of course the comparison between them is night and day.
The magnet is merely held on by a small screw, it should be an easy mod if the plug has enough depth to drill a hole and tap it while having enough thread to hold with and not penetrate all the way through the plug when drilling the tap hole. Use a little high temp. loc-tite and should be fine.
It's just an idea.
eh when it comes to those i try not to ebay that lol. something gets screwed up or lose...not gonna turn out good. but i need to find out the thread size of the plugs. allenaircraft.com has some crazy magnetic drain plugs...read up on them i believe if i read it right you can unscrew one part just to pull the magnetic part out to see the shavings, without letting oil out!!!
Did you ever find out the drain pan plug size? Any idea if it's the same plug used on the MS3?
no idea, i had it off the other day too and i was meaning to match up the threads but i was in a rush...boo. ill be doing another oil change in about 2 weeks so unless anyone else finds out the thread size ill get it.
I just put one in my MS6 3 weeks ago, during the last oil change. It's the same size (dia and thread) as for other Mazdas. I got it off eBay for about $6 shipped from Hong Kong (bought 2, one for my brother who has a Mazda5) with combined shipping.
The bolt head is different (IIRC it was 14mm, noticeably smaller than the stock one on the MS6, which I think was 17mm or 19mm?) but otherwise it went on fine. One item to note though, the one I got was made from aluminum, with a cylindriacl steel magnet inserted into the end (apparently pressed in as there wasn't any lock screw). If you get the same type I would strongly recommend doing oil changes yourself, to avoid ham fisted oil change "technicians" from stripping the bolt head.
I'm unsure if I will keep the bolt on the car long term. At this time I'm going to see if it picks up anything when I change the oil next. Depending on the result I may just reinstall the stock one.
BTW, if any of you are also active on the Mazda6.club forum I'm SuperCar Tastes - Skoka Budget over there.
