1991 Protege Overheating Problem
li Arc
Hey guys, so I'm having an issue with overheating. Normally, this wouldn't be a hard problem to troubleshoot. However, these are the following symptoms:
1) Radiator is cool to the touch
2) Top coolant hose is warm
3) Bottom coolant hose is cool
4) Coolant level unchanged
5) Coolant leaked from somewhere, some steam
6) Could not get 2-3 blocks without temp gauge hitting past "H" while car is warm.
So I checked and found that the thermostat housing was ajar, so I replaced with new thermostat and gasket.
This is the result:
5) No leakage, but steam still
6) Got about 3 miles/5 kms before gauge hits "H"
I found that the steam came from a major dent in the radiator, very close to the top coolant hose; this dent was also leaking. So, next I tried replacing the radiator; the replacement came with its own fan and its own pressure cap.
Now we have this:
2) Top coolant hose is slightly warm
5) No leakage
6) Fan doesn't turn on (could not get fan off replacement rad, so kept it on for now)
7) Got about 9 blocks before overheating.
For the record, fan turned on later, somehow. But not when I needed it to. I'll probably replace with original fan, but it's relatively cool out and if the car is moving, there still should not be any overheating with no fan. Besides, if it were truly hot and the fan would make a difference, wouldn't the radiator be hot as well? By now, I figure the water pump is bad, and I've got it stripped down to right before I remove the crankshaft pulley, and I find the pump is neither leaking nor is the bearing worn; the pump feels very solid still. So, instead, I decided to try tightening the belts to spec.
This happened:
5) No leakage
So, one way or another, coolant isn't moving around. However, I don't understand why the top coolant hose is still just a little warm? Is it possible the brand new thermostat is bad? I installed it the correct way, with the spring facing into the engine and the bypass hole at the top.
Or perhaps it's the fan? Or is it truly the water pump?
li Arc
Damn good thorough write-up man! I'm just guessing but sounds like the water pump is your culprit. Can you get one from the scrapyard?
Try to PM 91protegeDX as he's just about re-built his engine x2 IIRC..
Sorry, I should've posted the update earlier, but I figured it out...it was user error! But I was right about it being a thermostat problem...it seemed after installing the thermostat and putting everything back together, the thermostat slipped from its position and got lodged in with the gasket. I'm guessing when the assembly got tightened up, the thermostat was pressed up against the block on the spring end and wouldn't move. This also explains why the fan didn't go off; the fan is operated by the PCM on the coolant temp sensor on the other side of the thermostat housing; since hot coolant wasn't getting past the thermostat, the PCM figured nothing was going on and didn't switch on the fan.
Glad I sorted that out; that cool top hose just didn't make sense to me, and everything else seemed like it was still working. Replacing the water pump would have been a total PITA if I found out it was all for nothing, or worse, that it didn't fix anything and I would move on to a system flush...at least it stopped at a new thermostat and a junkyard rad...which I needed to replace the busted rad anyhow, and both relatively cheap.
Thanks for the suggestions guys!
li Arc
and here i was going to say that the T-stat sounds like it was put in backwards after reading all of that.. And if that wasnt the case i was goign to suggest running without a t-stat for trail to see if it was indeed a issue with your installation or water pump.... then again running the car hot so many times isnt a good thing.
